1997 Subaru Legacy Rear Diff Rebuild
SUBARU
REBELROY
i have a 1997 subaru legacy L with a automatic transmission and i need to rebuild the rear differential can anybody tell me how to get the gears and bearings out of the housing so i can replace them and what tools i need to use
Nov 11, 2007 at 8:21 AM
  • 31,937 POSTS
Hi there,
I would not attempt to do this your self, unless your a mechanic with differential experience or a VERY experienced home mechanic, set up tools vary and can be expensive, go get a re built unit of a second hand diff, re built units are expensive, because of the work that must go into the job. Have a good think about it.
Mark (mhpautos)
Nov 11, 2007 at 12:03 PM
Suggested Repair
Do not rebuild the rear differential at home unless you have differential experience and the proper setup tools. Buy a rebuilt or used rear differential instead.
Conversation Summary
The owner of a 1997 Subaru Legacy L automatic asked how to remove the rear differential gears and bearings and which tools are needed for a rebuild. The expert advised against a DIY rebuild unless the person is experienced with differentials, noting that setup tools vary and can be expensive, and recommended a rebuilt or second-hand differential.
