1984 Other Subaru Models CV Joints ?
1984 SUBARU
194,000 MILES • 4 CYL • 4WD • MANUAL
DALENAA07
I Have been having a Problem As of Late, the Subaru GL Wagoon, when Turning Left is really hard and seems to make what seems to be clunking/scrapping noise.. I but Left turn is still possible. Turn Right is Just fine. Also at high speeds, ( between 45-60Mph) when making corners the car shudders a little, and makes quite a bit of noise. the Shudder kinda feels like the tire is going to fold under the rim, and flopping. But at those speeds its shouldn't do that, and there wide corners too.
I dont know if the two problems are related.
Thanks a Bunch for your Time :-) Much Apperciated
Dec 2, 2008 at 1:14 PM
  • 31,937 POSTS
Hi there, get the L/H, drive shaft checked as well as the steering and suspension, i feel that it may be drive shaft related, start here.
Mark (mhpautos)
Dec 2, 2008 at 1:38 PM
DALENAA07
Thanks for the quick Reply :-D ill make sure and get the Drive Shaft Checked. Also i dont know if this helps but, the 4WD/ LO 4WD 2WD Switching Is Flawless, it works great.. i just replaced Rear differential oil and Manual transmistion Oil.. dont know if that helps. :-D
Dec 2, 2008 at 1:43 PM
LOUDOGSDAD
Your description of going around corners sounds exactly like what happened to me with my 94 subaru. It ended up being the CV joint.
Dec 17, 2008 at 3:28 PM
