1995 Subaru Impreza Dead After Axle Repair
SUBARU
MACHINIST16346
I have a 95 Impreza L 155,000 2wd ,5sp
I was changing my Right front axle and to get to the pin that is in the axle close to the tranny I disconnected some of the wiring haness.
I finished and connected everything back up and when I went to start it, nothing happened.
I mean no lights, door buzzer nothing. Completely dead.
Question:
1. DO I have to reset something to get it to start?
2. Would a fuse gone bad?
3. Could the fuseable link be a problem?
4. Possibility of the ignition fuse gone bad.
Things I've tried:
1. I tried to compression start it.
2. I dissconnected the battery to see if it would reset.
3. I've checked wires to see if the pulled out.
4. Rechecked my connections.
5. checked fuses.
6. I tried jump starting as well
It acts when I try to compression start that it isn't getting any current to start.
It ran like a top prior to me messing with it.
Thanks in advance
Steve
One other thing is when I dissconnect the fuseable link the door buzzer comes on and when I connect it again the buzzer goes off if that helps. But still no lights or anything else.
Sep 3, 2007 at 2:09 AM
MERLIN2021
  • 17,250 POSTS
It would be helpful if we knew if starter wires were removed...? Was neg batt cable disconnected prior to the repair? Sounds like a bad fuse link or blown ignition fuses...Possibly a disconnected engine ground? Try a single jumper cable from neg term, to the engine block. See if it will crank then?
Sep 3, 2007 at 4:24 AM
Suggested Repair
Check for a bad fusible link or blown ignition fuses and a disconnected engine ground. Temporarily connect a jumper from the battery negative terminal to the engine block and see if the engine will crank.
Conversation Summary
The owner of a 1995 Subaru Impreza disconnected part of the wiring harness while replacing the right front axle. After reconnecting everything, the car was completely dead with no lights, door buzzer, or cranking. Battery disconnect, fuse checks, and jump-starting did not restore power, though disconnecting the fusible link made the door buzzer sound. The expert suspects a bad fusible link, blown ignition fuses, or a missing engine ground, and suggests jumpering the battery negative to the engine block to test cranking.
