1996 Subaru Legacy L wagon 2.2 168,911/mi. No heat, bottom radiator hose cold - replaced t-stat; no difference. Why??
Mar 4, 2007 at 1:21 AM
SCUBARU
MEMBER
I would say either the thermostat is a poor quality replacement part. Or the vehicle has a flow problem such as worn water pump impelars or a resticted radiator.The last thing could be a large air pocket which is possible if the proper fill and bleed procedure wasnt followed with the thermostat replacement
Mar 4, 2007 at 12:16 PM
PSYLOSYFER
MEMBER
hold the garden hose tightly to the outlet of the core "bottom hose" have someone turn the hose on hi till clean water freely runs out the other tube, reassemble worked great for me after thermostat did not help
Mar 17, 2007 at 5:17 PM
