loss of power steering in 1998 subaru legacy/outback wagon
1998 SUBARU
ELEPHANTKILLER
1998 subaru legacy/outback wagon 140,000 miles 4 cylinder. Last night i was driving down the road and lost my power steering, when it happened my brake indicator lamp and battery indicator lamp came on. i checked the power steering fluid and i wasnt low enough to cause a loss of power steering. a friend told me it may be a broken belt but i havent been able to locate one if that is the problem. please help.
Feb 18, 2007 at 7:19 AM
KIN CHAN
  • 453 POSTS
definitely loss of crank drive...either belt or crank pulley....have ur engine running chk the crank pullley with the p/s pulley while some1 is reving up the car...if they don't move ...any 1 of em don't move..there's ur problem
Feb 18, 2007 at 7:24 AM
ELEPHANTKILLER
can i fix this or do i need a pro? If i do need a pro how much should it cost?
Feb 18, 2007 at 7:36 AM
MIKE H R
  • 3,094 POSTS
the belt sounds like the cause. it is located on the front of the engine just behind the cooling fans. on the hood should be a diagram of how it goes. you have to loosen up the altinator bolts and the adjusting bolt. make sure the belt is in place. then tighten the bolt on the top of the altinator that tightenes the belt. do not over tighten. then tighten the bolts for the altintor and adjuster.
not hard to do, i have a 1999 outback.
Feb 18, 2007 at 11:49 AM
SCUBARU
  • 71 POSTS
The splines on the inside of the power steering pump pulley can strip out over time.Casusing the the pully to spin but not turn the pump.
Feb 27, 2007 at 7:31 AM
