WHEN SCANNING CODE COMES UP LOW VOLTAGE READING AT KNOCK SENSOR,CANYOU TELL ME WHAT THIS MEANS AND WARE THE KNOCK SENSOR IS LOCATED ON THE ENGINE
Apr 25, 2007 at 3:04 AM
JAIME DEFORGE
MEMBER
WHEN SCANNING MY 1999 LEGACY 4 CYLENDER IT GIVES ME A CODE OF LOW VOLTAGE AT KNOCK SENSOR, CAN YOU TELL ME WHAT THIS MEANS AND WERE I WILL FIND ITS LOCATION ON THE ENGINE. THANK YOU
Apr 25, 2007 at 3:08 AM
MIKE H R
MEMBER
the knock sensor is located under the intake manifold runner on the left side of the engine. it is hard to see, look down where the throttle cables are, under it you will see it, a bolt is in the center holdng the sensor in place.
