JERKY AND CRUNCHING NOISE FROM DRIVE TRAIN
SUBARU
COMET60
1998 SUBARU 140000 MILES 2.5 AUTOMATIC HAS A JEKRY/CRUNCHING/ POPPING NOISE. (SORRY I CANT THINK OF A BETTER DESCRIPTION ) THIS OCCURS ONLY WHEN THE VEHICLE IS MOVING SLOWING AND IN A TURN IN EITHER DIRECTION SUCH AS AT AN INTERSECTION AND GIVING IT SOME GAS TO TURN RIGHT OR LEFT. ONCE AT SPEED OR DRIVING STRAIGHT ALL IS WELL. IN ADDITION TO THIS THERE IS ALSO SOME SHAKE AND VIBRATION THAT SEEMS TO OCCUR ONLY WHEN THE VEHICLE IS PULLING HARDER SUCH AS CLIMBING A HILL BUT DOES NOT SEEM TO BE THERE ALL THE TIME. I SEE THIS AS A SEPERATE PROBLEM BUT INCLUDE IT IN CASE SOMEONE ELSE THINKS IT RELEVANT. ALL THE DRIVE SHAFTS SEEM OK EXCEPT FOR ONE HAS A SPLIT BOOT.
Aug 11, 2007 at 3:34 AM
WHAT_THE_NUT
my 02 impreza was doing the same thing, but it started and within a week was undrivable. the mechanic wants to replace my transmission, so be aware, and let me know what you find out.
Sep 14, 2007 at 4:43 AM
VOYGER2
I have a 97 outback that does the slow turn jerking and thumping thing also.I went over the hole drive train twice.replaced a bad trans mount.That wasnt it.I think it is a rear cv joint.Dont know wich one.The both look fine from the outside.Im working on it this weekend.Ill let you know.chuck
Oct 17, 2007 at 11:56 AM
VOYGER2
[quote:e2a5e6de63="voyger2"]I have a 97 outback that does the slow turn jerking and thumping thing also.I went over the hole drive train twice.replaced a bad trans mount.That wasnt it.I think it is a rear cv joint.Dont know wich one.The both look fine from the outside.Im working on it this weekend.Ill let you know.chuck[/quote:e2a5e6de63] Well I put a fuse in the FWD holder under the hood to see what would happen and the the problem stopped completly.Next I canged the trans. fluid/filter and the problem almost has gone away.I removed the fuse.I still dont know what the problem is but its improving.Iv ruled out a rear CV joint.I will keep you posted.CHUCK
Oct 20, 2007 at 10:51 AM
VOYGER2
[quote:d6eb624727="voyger2"][quote:d6eb624727="voyger2"]I have a 97 outback that does the slow turn jerking and thumping thing also.I went over the hole drive train twice.replaced a bad trans mount.That wasnt it.I think it is a rear cv joint.Dont know wich one.The both look fine from the outside.Im working on it this weekend.Ill let you know.chuck[/quote:d6eb624727] Well I put a fuse in the FWD holder under the hood to see what would happen and the the problem stopped completly.Next I canged the trans. fluid/filter and the problem almost has gone away.I removed the fuse.I still dont know what the problem is but its improving.Iv ruled out a rear CV joint.I will keep you posted.CHUCK[/quote:d6eb624727]
Oct 24, 2007 at 10:15 PM
VOYGER2
after changing trans fluid/filter problem has stopped.The fluid was real nasty.I recomend a change.Now when I make a right turn the dome light comes on then goes out.Will it ever end?
Oct 24, 2007 at 10:39 PM
