Fuel pump?
SUBARU
BOB RIETH
I have a 96 Subaru Legacy L with a 2.7ltr engine. This winter the fuel pump went out. I had it replaced for $$$. Now it has died on the side of the road. There appears to be no power getting to the new fuel pump. Is there a fuel relay that might have died? If so, where is it located and how do I recognize it? The shop would be more then happy to trouble shoot the problem at $65.00 per hour!
May 12, 2007 at 9:53 AM
MIKE H R
  • 3,094 POSTS
the fuel pump relay is located in front of dreivers side, under dash, is mounted in the relay block.
May 13, 2007 at 5:23 AM
BOB RIETH
[quote:78a3b9932c="M_J_RITZEL"]the fuel pump relay is located in front of dreivers side, under dash, is mounted in the relay block.[/quote:78a3b9932c]
"I tried to buy a new fuel pump relay and both NAPA and Schucks say there is none on this make and model of Subaru. Any sugestions. There is no power getting to the fuel pump at all."
May 19, 2007 at 11:01 AM
MIKE H R
  • 3,094 POSTS
he is a diagram of location
https://images.2carpros.com/forum/automotive_pictures/54223_relays_subaru_1.jpg
May 20, 2007 at 2:59 AM
BOB RIETH
Wow, thanks! I also may have a solution that won't cost me anything. I talked to the owner of the repair shop and he said to bring the car back and they WILL trouble shoot it free of charge because it is under thier warentee. I will let you know how it goes.
May 20, 2007 at 7:47 AM
