DTC P0448
SUBARU
YOONIQUE
I'm looking for diagnostic procedure for DTC P0448 on 2005 Subaru Impreza, non-turbo, help appreciated
Jan 9, 2007 at 3:19 AM
BACKYARDMECHANIC
  • 337 POSTS
That code means there is a problem with the EVAP soleniod valve or circuit. This is part of the emmissions system for the vehicle. The car is a 2005 which means it is still under warranty. Most emmission parts on todays cars are required to be under warranty for five years. Before you do any work I suggest you contact the dealer and see if that part is covered. Good luck :D
Jan 9, 2007 at 3:33 AM
YOONIQUE
[quote:d508bbecbe="backyardmechanic"]That code means there is a problem with the EVAP soleniod valve or circuit. This is part of the emmissions system for the vehicle. The car is a 2005 which means it is still under warranty. Most emmission parts on todays cars are required to be under warranty for five years. Before you do any work I suggest you contact the dealer and see if that part is covered. Good luck :D[/quote:d508bbecbe]
Tnx, but I know what the code means,
I need diagnostic procedure for it, service manual has it (for example), there is no warranty since vehicle is overseas
Jan 9, 2007 at 5:38 AM
