1999 Subaru Forester Oil Use and Fuel in Oil
SUBARU
READY4ROLAIDS
I have a 1999 subaru forester 191,000 miles on a 2.5 liter engine. I bought the car with two burnt valves. I pulled the heads and had them rebuilt. I put it back together and it seems to run fine I am getting a small amount of gasoline in the oil. As well as the car is using oil about a quart every 400 miles, but I am not getting any smoke other then a small puff of blue when it fires up on a cold moring. I thought that it was the rings so I did a compression test three cylinders have 160 psi and one has 150 psi. I have looked for leaks all over the plave. I was wondering if my cylinders are being washed with too much fuel or if it is something else?
Oct 30, 2007 at 9:24 AM
  • 75,988 POSTS
Its burning it and for the fuel in the crankcase you better get rid of it and find out fast its no good. Start with pressure regulator and injectors-
Oct 30, 2007 at 9:37 AM
Suggested Repair
Drain the fuel-contaminated oil promptly. Check the fuel pressure regulator and injectors for leaking fuel into the crankcase. Cold-start blue smoke indicates the engine is burning oil.
Conversation Summary
A 1999 Subaru Forester with a rebuilt head uses about a quart of oil every 400 miles and has a small amount of gasoline in the oil, with only a brief blue puff on cold start and no external leaks. Compression is about 160 psi on three cylinders and 150 psi on one. The expert says the oil is being burned and that fuel in the crankcase must be removed and traced quickly, starting with the pressure regulator and injectors.
