Clutch Replacement
SUBARU
TBRANTSCOTT
I have a 1995 subaru legacy wagon with 199000 miles. The clutch is slipping and as soon as the weather breaks I am planning on replacing it. In addition to the service manual info, is there any extra advice, tricks, or other info that will help with the r&r?
Feb 17, 2007 at 8:58 AM
MIKE H R
  • 3,094 POSTS
what i would do, make sure you have everything you need including a clutch allignment tool and a torque wrench. before you put it all back to gether check everything. twice
Feb 17, 2007 at 11:52 AM
SCUBARU
  • 71 POSTS
Are you sure the clutch isnt just out of adjustment?I would make sure that there is suffecient freeplay before replacing the clutch.On a 95 as the disc wears you actually lose freeplay which sometimes doesnt allow the proper release of the clutch fork.
Feb 27, 2007 at 9:13 AM
