Bad Bearings? 98 Forester
1998 SUBARU
CHERYL68
My Forrester runs loud, the noise seem to come from the tires, similar to running on snow tires. The noise gets louder when driving faster, quiter when slowing down. Could this be bearings or the differential?
Please help! :!:
Nov 22, 2006 at 6:39 AM
JUSTIN.DUNLAP
if it gets loader when your turning one way and quieter turning the oppisite way the its most likely a wheel bearing... basically if you turn the the left and it gets louder then its the right bearing that is bad or viceversa....
Justin Dunlap
Nov 22, 2006 at 9:25 AM
JKTECK
Had same problem. Take it to dealer and Subaru will install a "new and improved" bearing. It's a common problem but you have to pay.
Jan 5, 2007 at 4:03 AM
MIKE H R
  • 3,094 POSTS
Have the car put up on a garage lift where the four wheels are off the ground. have someone in the vehicle with the engine running. put the car in drive. go around to each spring in front from under the car. a vibraton can be fealt when you put your fingers on the spring when the front tires are turning. if a good vibration is felt good chances that the bearing could be bad. but bearings usually make a noise when turning.
Feb 1, 2007 at 10:41 AM
