BACKFIRING 1987 STATIONWAGON 1800 OHC 4WD
1987 SUBARU
-LEEEROY-
I just bought a 1987 STATIONWAGON 4WD 1800 OHC MANUAL TRANS with 419,000km (about 250,000 miles) got it cheap all pretty good except for slight misfire and backfiring when changing gear.Replaced coil,dizzy cap,rotor,plugs and tested leads all good now runs well no misfire but still backfires. Dizzy needed max turning to get to 10 degree BTDC spec timing otherwise was way to advanced,[b:3a59e98990]suspect one of the timing belts one tooth out of specs, is this likely cause and will it cause backfiring? [/b:3a59e98990] Also it has catalatic convertor in exhaust system but inside has disentegrated to nothing due to age leaving pretty much a tin can inline of exh system.I think this is contributing as well as the excessively emissioned carby set up which iam thinking of replacing with basic type from older model 1800 OHV eng, any ideas,help thoughts much appreciated :)
Jun 10, 2006 at 8:39 AM
  • 110,246 POSTS
Make sure the guts from the converter didn't make it to the exhaust and partially plug it. Also, the type of backfire you have described, sounds like a vacuum leak problem. Check for leaks, damaged or dryrottes hoses, intake leaks...
Let me know if you find anything.
Feb 28, 2009 at 6:14 AM
