'96 Outback won't start when hot
1996 SUBARU
JSJOYCE
  • 5 POSTS
I have a '96 Subaru Outback wagon w/ 175,000 miles. It always starts right up when it is cold, however, if I'm out & about running errands w/ several stops & starts when it is hot, it will not start. I usually have to wait 15-20 minutes and then if I'm lucky it will start.
A mechanic is checking it out now, but they've already verified there's nothing wrong w/ the starter. They're looking at the fuel line.
If anybody has any ideas, I'd really appreciate your thoughts.
Thanks,
John
Nov 8, 2006 at 2:18 AM
KENDER
I've encountered this problem with a few Nissan Pulsars. It was the coolant temperature sensor located by the thermostat housing. I know this info isn't specific to a Subaru, but it might still help
Cheers
kender
Nov 9, 2006 at 7:11 AM
JSJOYCE
  • 5 POSTS
[quote:263b1777ea="kender"]I've encountered this problem with a few Nissan Pulsars. It was the coolant temperature sensor located by the thermostat housing. I know this info isn't specific to a Subaru, but it might still help
Cheers
kender[/quote:263b1777ea]
Thanks Kender, I'll have my mechanic check that out.
Nov 9, 2006 at 7:24 AM
KIT
JOHN,
IF YOUVE HAD THE PROBLEM FIXED PLEASE POST IT. MY 250T DOES THE SAME THING.
Jan 22, 2007 at 10:50 AM
JSJOYCE
  • 5 POSTS
Yes, we finally had this properly diagnosed & repaired. Of course, the paperwork is in my car and I can't recall the exact type of sensor that needed replacing (for $400), but the problem was that the sensor was making the car think it was at a higher altitude. At least that's the 2nd-hand explanation I got via my wife.
I'll try to post something more accurate when I get a chance.
Jun 29, 2007 at 1:55 AM
THEGID
John,
I've got a very similar problem and would like to know exactly what type of sensor needed replacing. See if I can get it fixed this weekend. Please see if you can make some time to review the paperwork.
Thanks a lot.
...Sanjay
Jun 30, 2007 at 3:20 PM
JSJOYCE
  • 5 POSTS
Hi Sanjay,
Sorry, but I just got back from a brief vacation. The repair invoice indicates the "pressure sensor" was replaced.
John
Jul 4, 2007 at 10:01 AM
WRX246
  • 39 POSTS
Replace your Cam & Crank angle sensors & car should start finw after that . they are known for doing that. Thanks
Aug 3, 2007 at 8:57 AM
BARTBOPP
John,
When you said it wouldnt start, did it even turn over? I have the same problem that happens occasionally with a 98 outback... it doesnt even turn over at that point. If I wait till it's cool, then it starts just fine.
Jun 12, 2008 at 6:35 AM
JSJOYCE
  • 5 POSTS
[quote:43a4eaa57f="bartbopp"]John,
When you said it wouldnt start, did it even turn over? I have the same problem that happens occasionally with a 98 outback... it doesnt even turn over at that point. If I wait till it's cool, then it starts just fine.[/quote:43a4eaa57f]
Yes, it would turn over. And if I flicked the ignition switch very quickly, it would start. Sometimes I would have to sit & wait a few minutes and then it would start.
We've since donated our Subaru, so it is somebody else's problem now! :-)
John
Jun 12, 2008 at 6:41 AM
