91 subaru legacy "height control" stuck ON! Please
1991 SUBARU
RFS3
I have a 91 subaru legacy wagon 4 door hatchback, that has the push button height control option. The switch is stuck on, and the vehicle is stuck in the high position, IE very bumpy ride, almost undriveable. I took the vehicle to a repair shop to have the problem repaired they said that I had leaks in the air bags which control the height control, and it would be tons of money to replace the system. I dont care about the height control, and just want it removed or disengaged.
I have tried pulling the fuses and disconnecting the battery to restart the ECU, with no luck.
What can I do, I just want it out of the the high position an driveable again. Can I some how disengage and disconect the switch?
Thanks very much,
Rachel
May 1, 2007 at 3:41 PM
MIKE H R
  • 3,094 POSTS
you can disconnect the power going to the air suspension, then loosen up the air control for each shock letting the air out leveling the vehicle,
https://images.2carpros.com/forum/automotive_pictures/54223_air_suspension_1.jpg
May 20, 2007 at 5:21 AM
GREASMUNKY
If you are not mechanically inclined you may want to consider just converting to a passive coil system. I got tired of the problems I was having with my Legacy last year. They told me the same thing ALMOST... they told me that my compressors were bad. I bought new compressors and BAM.. shortly after back in the shop buying new airbags this time and a new compressor to replace the NEW one that the airbags just killed!!! I had heard about Strutmasters.com so I checked them out. It has been 8 solid months riding on my new conversion kits and I love them. They have a lifetime warranty (unlike ANY air suspension parts you will EVER find), the people were helpful and I actually prefer the coil spring ride to the air ride. Hopefully this helps a little. I would hate to hear you have to spend as much money as I did just to learn the same lesson. Good Luck!!!
Apr 28, 2009 at 8:18 AM
