2002 Subaru WRX Squeaking
2002 SUBARU
CANTAF1068
Make: Subaru
Model: Impreza WRX
Year: 2002
Mileage: 64,000
This started about a month ago, and I just ignored it for a little while, but it seems like it has gotten a little worse. I hear a slight squeaking noise towards the right front area of the car sometimes when I am transitioning from 3rd to 4th gear and higher. The squeaking occurs right in the middle of the transition of coming off the clutch while pressing on the gas, specifically when I come off the clutch a little early and the car vibrates a little bit. Same noise also happens when I come off the gas real quick without pushing the clutch down. Every once in a while, I hear it just driving along, without accelerating or decelerating, but not as much as when transitioning from gear to gear. At first, I thought it was a problem with the springs and such, but there was no squeaking when I pushed down on the car from the outside. Any suggestions/ideas will be greatly appreciated.
Mar 9, 2006 at 7:12 AM
CF_ANDERSON
  • 20 POSTS
I doubt it is your shocks. I think you have a belt problem. The belt might be too dry or is a little loose and could be slipping. Very easy fix to tighten the belt or if you notice it is dried out and has some cracks, get a new belt before it breaks.
Mar 9, 2006 at 11:08 AM
