2001 Subaru Outback Low Idle
2001 SUBARU
BRANDOLPH
Hello, I've recently moved to a new city and I don't have a mechanic that I trust yet and I don't want to lose my savings going to a dealership...I'm not great with cars but I can follow directions very well. My car has been idling low (around 500-600 rpm) I've only owned the car for a year and I've never had any major work done on it, just oil/lube changes etc. Also, the steering wheel gets very stiff when turning it all the way to the left. Any help someone could give me on this would be greatly appreciated.
Thanks,
Brian
Oct 17, 2007 at 7:53 AM
  • 75,988 POSTS
Is it 2.5L or 3.0L engine?
Oct 18, 2007 at 11:04 AM
BRANDOLPH
sorry i'm not sure...how would i tell?
thanks for being patient with me
Oct 18, 2007 at 11:32 AM
  • 75,988 POSTS
Look at your VIN's or under the hood at VECI somewhere it would tell what liter.,
Oct 18, 2007 at 11:55 AM
BRANDOLPH
ok its a 2.5
Oct 18, 2007 at 12:04 PM
  • 75,988 POSTS
Within the year is there any type of tune-up done it? if not I suggest you do so. Might want to check the idle air control valve solenoid located on the throttle body see below
https://images.2carpros.com/forum/automotive_pictures/12900_2001_subaru_outback_IACV_solenoid_1.jpg
Oct 18, 2007 at 6:36 PM
Suggested Repair
If no tune-up has been done within the past year, perform one. Also inspect the idle air control valve solenoid on the throttle body. The stiff steering when turned fully left was not diagnosed in the thread.
Conversation Summary
The owner of a 2001 Subaru Outback automatic with a 2.5L four-cylinder and about 90,000 miles reported low idle around 500-600 rpm and a steering wheel that becomes very stiff when turned fully left. No major service had been done beyond oil and lube changes. The expert confirmed the 2.5L engine and recommended a tune-up if none had been done within the year, plus inspection of the idle air control valve solenoid on the throttle body.
