1999 Subaru Legacy/Outback Wagon AT
1999 SUBARU
PETER PARKER
Hello I just recently bought a 1999 Subaru Legacy/Outback wagon the chassis has only 119,000 miles on it with a completely rebuilt 2.5ltr DOHC engine which only has approximate 3200miles on it; and my question today is about 1300miles ago my speedometer just shut down going down the highway, but not for good it shuts off about 30% of the time and the other 70% percent it works just fine. I know and have been informed that this is a speed sensor issue. But can it be an easy and inexpensive fix? Can I unplug the plug on the passenger side of the tranny to clear up this problem or is it just going to get worse over time? :roll: :?: I called up the local Subaru dealer and their parts counter said that the speed sensor was tied into the main wiring harness :( and the cost for it was approx $286.00 :shock: way more than I can or even want to pay @ this time . Isn't it too soon meaning before 150k miles for this kind of problem to be happening ? Is there an easier less expensive solution to fixing my speed sensor problem? thank you , peter parker
Jun 26, 2006 at 1:18 PM
MIRPAT2780
[quote:a5c1787cbe="peter parker"]Hello I just recently bought a 1999 Subaru Legacy/Outback wagon the chassis has only 119,000 miles on it with a completely rebuilt 2.5ltr DOHC engine which only has approximate 3200miles on it; and my question today is about 1300miles ago my speedometer just shut down going down the highway, but not for good it shuts off about 30% of the time and the other 70% percent it works just fine. I know and have been informed that this is a speed sensor issue. But can it be an easy and inexpensive fix? Can I unplug the plug on the passenger side of the tranny to clear up this problem or is it just going to get worse over time? :roll: :?: I called up the local Subaru dealer and their parts counter said that the speed sensor was tied into the main wiring harness :( and the cost for it was approx $286.00 :shock: way more than I can or even want to pay @ this time . Isn't it too soon meaning before 150k miles for this kind of problem to be happening ? Is there an easier less expensive solution to fixing my speed sensor problem? thank you , peter parker[/quote:a5c1787cbe]
Apr 29, 2007 at 12:37 PM
MIRPAT2780
I have the same problem on the same make model and year. I have searched for a solution myself or even information on how I could attempt the repair my self with no luck. I could use any info you have on this matter.
Apr 29, 2007 at 12:41 PM
MTNBIRDLADY
I had that problem with my 1999 Legacy Outback Wagon 2.5. I would be driving and would loose the speedometer and odometer for a bit and then they would return. After a year of trying to convince subaru of the problem, they finally replace the speedometer unit. I haven't had any trouble since. I now have 68,000 + on the new speedometer. It failed at 61,020.
Jul 15, 2007 at 6:48 PM
WRX246
  • 39 POSTS
hello i could proberly help you both
i've got a copy of the repair manuals i'm presuming these are much the same as the impreza engine wise
i'll look it up for you
thanks carlisa
Jul 16, 2007 at 1:28 PM
