1999 Other Subaru Models 1999 subaru legacy outback wagon ac
1999 SUBARU
124,480 MILES • 4 CYL • AWD • AUTOMATIC
RUMAN88
I have a catback exhaust and a short ram air intake on it! Nothings really wrong I just want to stop the normal accelerator lag! For example when I'm at a stop and stomp on the gas the motor falls on it's face then takes off. If you can tell me what part/parts I can add or what mods I can make to stop the accelerator lag it would be greatful! Thanks!
Jul 31, 2009 at 3:50 PM
Your problem could be caused by the following:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 31, 2009 at 10:26 PM
