1997 legacy L knock sensor
1997 SUBARU
REBELROY
i have a 1997 subaru legacy L and the knock sensor is bad where is it located and what is the best and easiest way to change it
Nov 18, 2007 at 7:34 AM
MIKE H R
  • 3,094 POSTS
the knock sensor is located under the intake manifold on the rear of the engine. it is threaded into the block. careful when removing it as the coolant in the block will run out draining the block
Nov 18, 2007 at 7:53 AM
