1996 Subaru Heater Problem
1996 SUBARU
JEFFC
Heater problem
1996 Subaru V4 All Wheel Drive 250000 miles
My car heater will work just fine while I am driving but the moment I stop and idle it will immediately start blowing cold air. When I start to move again, the heat starts right back up. I did check the coolant level and it is fine. Any ideas?
Dec 2, 2007 at 4:54 AM
MERLIN2021
  • 17,250 POSTS
Try warming the Vehicle, then carefully feel the heater hoses, are they both hot? If one is cooler than the other, You need to flush the core, or a replacement job on the heater core. Also if the system has a heat control valve on the heater hose, make sure it is working!
Dec 2, 2007 at 6:34 AM
