1992 Other Subaru Models clunk!!
1992 SUBARU
150,000 MILES • 4 CYL • 4WD • MANUAL
JAMESMOON007
hello
My subaru l series sports wagon has just developed a new noise when operating the clutch pedal.
It is worse when releasing the pedal under load as in going up a small hill...it is a clunk sounds like somthing has come loose...?
the clutch does not slip and both the front cvs have been replaced recently...
thanks for any help
james[img:c7ff76ae7d]http://www.2carpros.com/forum/automotive_pictures/157349_24122007514_1.jpg[/img:c7ff76ae7d]
Feb 11, 2008 at 8:24 PM
  • 110,248 POSTS
Hi:
Is the clutch still releasing smoothly? If not, you may have a broken spring on the pressure plate. Also, check trans mounts and motor mounts.
Feb 28, 2009 at 5:53 AM
