1991 subaru justy
1991 SUBARU
CWE909
  • 14 POSTS
where is and how to replace themostat 1991 subaru justy 1.2 fi has vin 8 also is 4wd
Apr 25, 2007 at 5:51 AM
ASHFOR20
My justy is an 89' but I'm pretty sure they're all the same. first i would drain the radiator there is a plug on the bottom drivers side i believe. then remove the air filter and air filter pan the thermostat is under there. next you can see the hose that comes off of the radiator to the engine. just losen those two bolts remove old thermostat and seal and replace. I have chilton book and it lead me to the lower radiator hose and that was wrong.
May 1, 2007 at 8:15 AM
CWE909
  • 14 POSTS
my haynes shows it to be underneath the intake manifold, with a bunch of parts to be removed just to get to it?
May 2, 2007 at 8:16 AM
