1991 Other Subaru Models head gasket
1991 SUBARU
HENDO23
Engine problem
1991 Other Subaru Models 4 cyl Front Wheel Drive 160000 miles
if your head gasket blows, how likely is it that more problems inside the engine are created and what problems might they be? Also how much are you looking to pay to replace the head gasket?
Jan 1, 2008 at 2:27 PM
  • 31,937 POSTS
The heads will have to be crack tested at a minimum, also checked for twist, Subaru uses a steel head gasket and the mating surfaces must be mirror finish , no nicks, scratches, or marks at all, other wise head problems will haunt you again. As far as costs go, this will vary on who does the work Dealer or independent, genuine or non genuine parts and head work required, this is unknown untill heads are removed.
Mark (mhpautos)
Jan 1, 2008 at 2:34 PM
