1988 Other Subaru Models Trouble starting cold
1988 SUBARU
250,000 MILES • 4 CYL • 4WD • MANUAL
WTW6
  • 5 POSTS
My 1988 subaru GL with fuel injection has a problem starting in the morning, especially if it's cold outside. After the needle gets above the "c" on the tempurature gauge then it runs fine with no stalling. Before that I have to rev the engine whenever i slow down. Thanks
Mar 21, 2008 at 3:22 PM
BLACKOP555
  • 10,386 POSTS
im going to go with the good old coolant temperature sensor causing your problem.
also check your IAC module and make sure the throttle body is clean!
Mar 22, 2008 at 12:07 AM
MERLIN2021
  • 17,250 POSTS
ECT resistance can be checked with an ohm meter, at 68 degrees it should be 2000-3000 ohms, There is a cold start injector on this engine, remove and clean out any carbon, reinstall and see how it runs...
Mar 23, 2008 at 2:20 AM
BLACKOP555
  • 10,386 POSTS
would also like to add on what merlin says about the temp and the resistance values.
assuming your IAT sensor is good you can compare the resistance between the two and they should be very similar.
Mar 23, 2008 at 2:54 AM
