1988 Other Subaru Models rear wheel bearing removel
1988 SUBARU
238,000 MILES • 4 CYL • 4WD • MANUAL
MRQUAINTANCE57
the manual I have only gives me instructions for repacking bearing on a 2 wheel drive. I need to repack the rear wheel bearing on a 4 wheel drive. I have the axle shaft removed but not seeing exactly what procedure would be for getting spindle and bearings out of hub. This is a 3 door coupe model, there are no stickers on doors or anywhere on the car. I beleive it often falls under the GL desination. don't know that for sure though. Some parts houses show it in their books and some don't. This is a Subaru assembled in Japan!!
Nov 27, 2008 at 4:32 PM
DAVE H
  • 13,384 POSTS
WHEEL BEARINGS
Removal (4WD Models)
Apply parking brake. Remove cotter pin and loosen castle nut. Disconnect shock absorber from inner arm. Loosen lock bolts of crossmember outer bushing.
Raise and support vehicle. Remove rear wheels. Separate front drive axle shaft from hub and support out of way. Remove castle nut and brake drum or disc/hub assembly (if equipped).
Disconnect brake line from brake hose at inner arm bracket. Remove brake assembly (drum brakes) from trailing arm. Remove bolt holding inner arm bushing mount to crossmember. Remove 3 bolts connecting inner arm and outer arm. Remove inner arm.
Put inner arm in a vise. Straighten staked portion of ring nut. Using Socket (925550000), remove ring nut. Remove spindle by lightly tapping inward with a plastic hammer. Remove outer oil seal from inner arm housing. Press bearings and races from housing and spindle.
Installation
To install, reverse removal procedure. Tighten ring nut to specification. Lock ring nut by staking a point on housing surface facing ring nut groove.
Install new inner and outer oil seals using Installer (925530000). Tighten castle nut to specification. Ensure washer is positioned behind castle nut. Bleed brakes. Check rear wheel alignment. See appropriate article in the WHEEL ALIGNMENT section.
Nov 29, 2008 at 10:45 AM
MRQUAINTANCE57
Hello Dave H,
First off, let me apologize for being so tardy in thanking you for your reply to my e-mail. I had to go back on shift, 12 hour shift 2 hour commute. Your reply is much appreciated. As soon as I’m back on my time I will put it to use. Now, back to the grind.
Thanks again,
Michael Q
P.S. don't get the points thing, tried to give but said I couldn't give more than I had ???? no help link I could see
Dec 1, 2008 at 11:42 PM
DAVE H
  • 13,384 POSTS
not a problem .. if ya need more info let me know ??
Dec 2, 2008 at 8:43 AM
