1987 Other Subaru Models Intake Manifold gaskets
1987 SUBARU
150,000 MILES • 4 CYL • FWD • MANUAL
TONYKING
I am replacing both intake manifold gaskets because of leaking coolant problems.
QUESTION: DO i JUST INSTALL THE GASKET BY ITSELF OR SHOULD I COAT IT WITH SOME TYPE OF SEALANT FIRST?
Jun 15, 2008 at 7:40 AM
KHLOW2008
  • 41,814 POSTS
Hi TONYKING,
A good gasket is self sealing when it heats up and requires no additional sealants, but if the coolant port is corroded, then some sealant might be required.
CAUTION : Some sealants will cause the gasket to distort. Don't use liquid type.
Jun 16, 2008 at 3:50 AM
