1991 Subaru Liberty Water pump removal
1991 SUBARU LIBERTY
16,800 MILES • 4 CYL • AWD • MANUAL
KAIT1975
Hi, we need to lock the crankshaft to enable us to remove the pulley, to get the timing cover off. To then have access to the water pump. What is the best way to do this? Is it necessary to remove the timing belts? Do we need to do that, then re-adjust the timing when it comes to putting it all back together again? Thanks very much.
Oct 12, 2009 at 9:01 PM
BMRFIXIT
  • 19,053 POSTS
Never seen a liberty made by Subaru
go to this link and pick your model and that will take you to timing belt diagram
https://www.2carpros.com/car_repair_information/year/1991/make/subaru.htm
Impact tools is used for the removal of the crank shaft pulley bolt
timing belt need to be removed and I would recommend replacing the belt too
Oct 12, 2009 at 11:29 PM
