1991 Subaru Liberty
STUMPPED
Engine Cooling problem
1991 Subaru Liberty 4 cyl All Wheel Drive Automatic
I've got a 91 liberty thats overheats when drivin but not while sitting idling. I've had the headgaskets replaced and heads checked, replaced the water pump and thermostat and quite frankly im at a loss! it can overheat in a matter of minutes and when it does i lose my heaters! i know there in no air in the system so just wondering if you have any ideas???
Sep 28, 2010 at 1:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely culprit is clog in the system, either heater core or radiator, even a hose could have something blocking coolant flow. need to flush system.
Sep 28, 2010 at 1:37 PM
