2006 Subaru Legacy Brake light
2006 SUBARU LEGACY
59,000 MILES • 4 CYL • AWD • AUTOMATIC
JWMEUSE
How complicated is it to replace a brake light on this Subaru? My husband is willing to do it for me if it isn't too complicated and I can access instructions. Thank you!
Mar 25, 2010 at 3:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if its the sedan model then all you do is remove the trunk side trim cover to access the brake light bulb. if its the wagon model you have to remove the light assembly by removing the clip, then pressing the section (A), insert your finger or flat tipped tool into the clearance and remove the claws in order of C D E and remove the cover. then remove the 2 bolts and detach the assembly by pulling it to the rear side of vehicle. now that its pulled out you can access the brake light bulb.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_10.png
Mar 25, 2010 at 3:24 PM
