Trunk light not working?
119,200 MILES • 4 CYL • AWD • AUTOMATIC
KERRYLYNN
I have a trunk light that will not light. I have now voltage at the light socket. I can not find the switch that operates to turn on the light. I have checked all fuses. I am struck as to what to do?
Nov 2, 2008 at 11:23 AM
Good morning,
I attached a wiring diagram as well as the location for you in the trunk.
Check for power to the bulb. If it does not have power, it comes from the fuse I circled.
Trunk Room Light
REMOVAL
1. Disconnect ground cable from battery.
2. Disconnect harness connectors and remove trunk room light.
INSTALLATION
Install in the reverse order of removal.
Feb 4, 2021 at 6:05 PM
