2004 Subaru Legacy Smell Antifreeze Burning
2004 SUBARU LEGACY
87,000 MILES • 4 CYL • AWD • AUTOMATIC
DAVISPEG
I can small the antifreeze burning, and the antifreeze is evaporating. I don't see any antifreeze on the ground. The heat gage does not indicate the car is overheating. What is causing the smell and the smoke? Thanks.
Jan 25, 2009 at 8:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If you can not see any drops of coolant then this usual indicates a cracked intake or other gasket. The crack in the gasket allows the coolant to go into the combustion chamber and be burnt out through the exhaust, causing the smoke. To learn more about this, follow the link below.
https://www.2carpros.com/first_things/white_smoke_steam_exhaust.htm
Thanks for using 2CarPros.com!
Jan 25, 2009 at 9:19 AM
