2003 Subaru Legacy do I need refill
162,000 MILES • V8 • AWD • AUTOMATIC
YVPRASRN
A/C works best when driving after car is off for awhile, when temps are around 80, less so well when 90's. A/c blows hot air when driving on an uphill drive (just regular no problem uphill), then kicks in again when driving downhill (cools well then). Is it getting kind of empty in there, is it something I can refill? There are plenty kits around. And if yes,,,where is the place i'd fill it in? Is it marked? (Haven't actually looked, but will tomorrow. So, other than hot air going uphill, there doesn't seem to be anything else. I am a highway driver mostly.
Thanks
Yvonne
Jun 10, 2008 at 5:40 PM
2CARPRO JACK
  • 11,533 POSTS
Depending on how much throttle you give it, the a/c will shut off for more power. You can get a kit to fill the system, but i suggest having a shop do it with the proper gauges to check the pressures so as not to damage the compressor and also for optimum performance
Jun 11, 2008 at 12:48 AM
