2001 Subaru Legacy Catalytic Converter Query,
2001 SUBARU LEGACY
155,000 MILES • 4 CYL • AWD • AUTOMATIC
PRAS_RAO
My 2001 Legacy Outback has been putting out the "Check Engine" sign on ond off for past few weeks. It comes on and stays for about 3-400 miles. It goes away when I refuel and comes back on at 100 miles after refueling. I just had a 150K servicing done by the dealer and reported the concern. At that time check engine light was off. The dealership called back with the check engine code reporting catalytic converter problem and should be replaced.
I did not have then do the work. Next day the check engine light came back on.
Is it related to the gas cap or the catlytic converter?
Prasanna
Mar 28, 2008 at 9:31 AM
MASTERTECHTIM
  • 4,750 POSTS
next time the light comes on, take it to autozone and have them scan it and give us the code and i will tell you. autozone will scan it for free.
Mar 28, 2008 at 10:15 AM
PRAS_RAO
The light came on again.
The code is P0420
Mar 31, 2008 at 7:23 AM
MASTERTECHTIM
  • 4,750 POSTS
PROBLEM IS THE CAT CONVERTER. you will need to have it fixed by the next time you need a emissions test for a inspection sticker
Mar 31, 2008 at 9:52 AM
