I want to convert to a duel exhaust system. Is it possible and what do I need to do with the o2 senser?
Dec 21, 2007 at 5:30 AM
BLACKOP555
✓Experienced Mechanic
you can buy a new wiring harness *expensive* or you can use a single o2 sensor on the side of the car with the #1 cylinder and it should run right, if not you will have to buy a wiring harness and wire up 2 o2 sensors.
