2000 Subaru Legacy blinkers, odometer, etc not working
BACKPACKER
  • 5 POSTS
2000 Subaru Legacy 130,00 miles
My daughter recently hit a deer with her Subaru. The impact broke the driver's side headlight assembly but apparently nothing else. However, the blinkers and odometer no longer work, and the check engine light, which was on, is no longer. The wipers seem to run slow too. I checked the fuses and all seem fine. I don't know about the relays though, as I don't know how to check them. I should mention that just before the accident, I replaced the alternator and had the battery unhooked to have it checked for voltage. In doing so, I did cause quite a spark when the battery cables came in contact with the terminals. Did I fry something then?
Dec 17, 2008 at 5:31 AM
MIKE H R
  • 3,094 POSTS
with reference to the engine light when you disconnected the battery it reset the computer, After being driven about 50 miles it will have reset itself. If there is a problem the engine light will come back on. The blinkers may have a bad ground or broken wire, check the wires and sockets. On my subaru I had to clean out the socket to get a good connection. With reference to the wipers running slow, With vehicle running disconnect the battery, the car should run with out the battery hooked up. If not have the charging system checked at someplace like auto zone or any other parts supplier. The will check it for nothing.
Dec 17, 2008 at 2:56 PM
BACKPACKER
  • 5 POSTS
[quote:7aece1c0f1="M_J_RITZEL"]with reference to the engine light when you disconnected the battery it reset the computer, After being driven about 50 miles it will have reset itself. If there is a problem the engine light will come back on. The blinkers may have a bad ground or broken wire, check the wires and sockets. On my subaru I had to clean out the socket to get a good connection. With reference to the wipers running slow, With vehicle running disconnect the battery, the car should run with out the battery hooked up. If not have the charging system checked at someplace like auto zone or any other parts supplier. The will check it for nothing.[/quote:7aece1c0f1]
Thanks for your answer. But why would the digital odometer not work? Could this be the result of a bad relay?
Dec 17, 2008 at 11:19 PM
MIKE H R
  • 3,094 POSTS
you said that you had a spark when the you replaced the altinator, It may be just a fuse. check the fuses on the drivers kick panel
Dec 18, 2008 at 12:35 AM
BACKPACKER
  • 5 POSTS
[quote:807a2d4cdc="M_J_RITZEL"]you said that you had a spark when the you replaced the altinator, It may be just a fuse. check the fuses on the drivers kick panel[/quote:807a2d4cdc]
I believe the odometer and blinkers were working before the deer accident (still waiting for confirmation on that). Damage was not excessive, just bent the fender and broke the headlight assembly. The battery connection was still good. I checked the fuses under the hood and they were fine.
Dec 18, 2008 at 12:56 AM
MIKE H R
  • 3,094 POSTS
there are fuses under the hood and also by the drivers side kick panel, the ones under the hood have relays for the headlights. there is also a fuseable link towards the frontof the box.
Dec 18, 2008 at 5:21 AM
BACKPACKER
  • 5 POSTS
[quote:ddb9c5570b="M_J_RITZEL"]there are fuses under the hood and also by the drivers side kick panel, the ones under the hood have relays for the headlights. there is also a fuseable link towards the frontof the box.[/quote:ddb9c5570b]
I'm sorry, I forgot to mention that I checked out the fuses under the dash that I thought would be relevant. They were fine. That's why I keep asking about the relays. Fusable link?
Dec 18, 2008 at 6:58 AM
MIKE H R
  • 3,094 POSTS
I tried to download you a diagram of the relays under the hood. I had just came back from off this website because of moving and was unable. I looked it up. The fusable link in that compartment runs such as the ignition switch. that are 5 in there run the a/c , rt and left head light.
The one for the directionals is on the bottom kick panel inside the car on the drivers side. just above the fuse box. Directly above the hood release lever. To get at it you have to take down the hood release lever and on top of the relay is a screw that holds it in place. Sorry I could not download the pictures.
Dec 18, 2008 at 10:39 AM
BACKPACKER
  • 5 POSTS
[quote:21ef6c0711="M_J_RITZEL"]I tried to download you a diagram of the relays under the hood. I had just came back from off this website because of moving and was unable. I looked it up. The fusable link in that compartment runs such as the ignition switch. that are 5 in there run the a/c , rt and left head light.
The one for the directionals is on the bottom kick panel inside the car on the drivers side. just above the fuse box. Directly above the hood release lever. To get at it you have to take down the hood release lever and on top of the relay is a screw that holds it in place. Sorry I could not download the pictures.[/quote:21ef6c0711]
Thanks for your help. I will look at it again this weekend. I assume that I will be able to tell if something is wrong with the fusable link once I pull it out.
Dec 18, 2008 at 10:46 PM
