car with unfixable TPS code
144,000 MILES • 4 CYL • 4WD • AUTOMATIC
CLEARANCEMAN
  • 14 POSTS
I don't know what to do, neither the dealer or a local shop that just fixes Subarus has been able to fix this car in more than 2 years.
2000 legacy wagon L I bought it new in 1999.
A few years ago, it started with TPS (throttle position sensor codes). The dealer replaced every sensor, the fuel filter, etc. proclaiming it fixed each time. I couldn't afford to keep doing this, so I went to a local shop. They are much cheaper but still can't figure out what is wrong. Here is what it does: It is not the TPS or the computer. I'm 100% sure. I have replaced both with no effect. TPS has been adjusted for voltage over and over too, no effect.
When you first start the car, it often shows low voltage TPS code and most of the time the ATF yellow light flashes. You can't drive it with the ATF light flashing (it slams gears) so I have to restart. Sometimes more than 10 times to get the ATF light to stop flashing. It rarely shows this code at start up if the temperature is below freezing (32 degrees). Occasionally, but not very often. It does it most of the time if the temperature is above freezing.
It sometimes throws the ATF flashing light in stop and go traffic, always as a result of TPS code. It does it most at start up, less in stop and go traffic. It also surges at random at idle and in traffic. The only way I have found to get rid of the flashing yellow ATF code is to restart the car.
On the highway, it sometimes stumbles and surges when the throttle is off (down a hill) but rarely throws the flashing yellow ATF code.
So I have noticed, the ATF code (and of course TPS code) is related to the amount of throttle. And at start up, it is also related to temperature. When under load (giving the car throttle), it doesn't occur.
Local shop noticed some TPS voltage fluctuation and asked if the TPS was replaced. This is with a brand new (bought last week) TPS in place. So there is low TPS voltage at 0 throttle and minimal throttle, but not at higher throttle levels.
Voltage at idle off the alternator is excellent, that was a thought that the local shop had. But it is 13 to 14 volts even at idle with accessories running.
Last week it started showing the factory security system on (red light blinking in the instrument panel) any time the engine is off. Doors closed or open, unlocked. It's always blinking. It doesn't set the alarm off though unless the doors are locked like normal. It just indicates it is armed. The security light goes off when the car is started. I have no idea if this is related to the TPS code. I care much less about the security system problem then fixing the TPS problem.
Mar 1, 2009 at 11:59 PM
MERLIN2021
  • 17,250 POSTS
TECHNICAL SERVICE BULLETIN Reference Number(s): 16-65-99R,  Date of Issue:   April 03, 2000 Related Ref Number(s): DESCRIPTION In the event you encounter a customer complaint of the A/T temperature light flashing and this code is found in the TCM, perform the following: First, eliminate all wiring and connector concerns by performing the tests as outlined in the appropriate Service Manual for this code. Repair as necessary. After you have checked and confirmed these items, and you still did not find any problems, we recommend you replace the following part(s). Use the chart below to locate and order the correct part number(s) for your application .
https://images.2carpros.com/forum/automotive_pictures/62217_suba_1.jpg
That part # is 31711AE10B I'm not sure what it is but it mifgt be the TCM itself...Stop in at Subaru, they can tell you if it's been done on yours yet, Transmission control module?
Mar 2, 2009 at 7:06 AM
CLEARANCEMAN
  • 14 POSTS
Could the code be low voltage TPS because that is the only one that ever shows up. No TCM codes despite the flashing ATF light at times.
Mar 2, 2009 at 10:40 AM
MERLIN2021
  • 17,250 POSTS
I think it's worth the effort to find out if the has been done or not, strange things happen with eleictrical and computer faults..
Mar 3, 2009 at 10:37 PM
CLEARANCEMAN
  • 14 POSTS
The TCM has definitely not been done. Can I use one from a 2001 or 2002? Different part number. I'm having trouble locating a used one for 2000 on ebay and a new one is $400.
Mar 5, 2009 at 1:29 PM
HELPING YOU
  • 100 POSTS
I'm wondering why "every sensor" would have been replaced>Does the (butterfly) shaft in the throttle body have a lot of play? I seem to remember seeing these replaced - I suggest you give a different dealer or Subaru specialty shop your next oil change business and run the story by them - Also I noticed the factory Shop Manual on CD is very inexpensive on ebay - there's a LOT of info in them but the translation from Japanese makes it hard to dechipher sometimes...
Mar 5, 2009 at 1:59 PM
MERLIN2021
  • 17,250 POSTS
Check the part number on the chart, it's the only one for your car that will solve the problem.
Mar 5, 2009 at 11:01 PM
CLEARANCEMAN
  • 14 POSTS
Ok, I'll check the butterfly valve. The local dealer is clueless, they just replace parts and call it fixed, they have no idea what is wrong. It's had 2 O2 sensors, a MAP sensor, 2 knock sensors, three TPS sensors. I replaced the computer. Hasn't had the TCM or the butterfly shaft. Can't figure out why temperature makes a difference either, above freezing way more problems than below freezing.
Mar 6, 2009 at 1:25 AM
POGODOG
Wow, finally I have come across someone who is having the same problem as I am
Let me do a quick run down here:
I also own a 2000 Legacy L 2.5 Wagon with 80k
My car has the same symptoms as yours does
I have replaced the TPS twice
Replaced the ECM (engine control module)
Just recently (about a week ago) I replaced the transmission control module (still nothing)
Car will be driving fine then all of a sudden the AT Temp light will start flashing and transmission will slam into gear with lots of throttle hesitation. As you stated above sometimes pulling over and shutting engine off will turn AT Temp light off. I'm at the end of my rope with mechanics unable to properly diagnose this problem (they rely way too heavily on scanning machines) I continue to get the same trouble code that suggests that the throttle position sensor needs to be replaced (again)
Does anyone have any sound advice on what is causing this problem? Any suggestions on something related that could be causing it? I'm at wits end and really don't know what to do
Mar 21, 2009 at 9:54 AM
MERLIN2021
  • 17,250 POSTS
It sounds like a manufacturing defect, time to call
N.T.H.S.A. at 1-888-327-4236, file a complaint, when they get a few of them, they force recalls...I agree about the techs and scan tools, but until the genius at the top who designed the crap figures it out, it's all they have!
Mar 22, 2009 at 3:26 AM
KARENCAREN
  • 72 POSTS
My mechanic friend thank you all. He is looking for this info to fix the car that a client gave him. I'll let you know guys if he fix it.
May 19, 2009 at 5:41 PM
MORIYA
This was good to read. I also own a 2000 Subaru Outback. I have been experiencing the same issue since I bought the car used from a Subaru shop in West Virginia.
I had to replace the TPS sensor twice in the 1st 3 months. I then drove across country and had to replace the TPS again! Then, the car started messing up again and the mechanics just can't figure it out. They replaced the computer as well as the battery. At one point I was told that I needed to take out my floor mat because it was too "heavy". Seriously?
Agreed. I only have troubles with the TPS Sensor when it's hot outside. Not sure what's up. However, after 3 years of issues, I'm sick of dealing with it and paying for it. I'm calling N.T.H.S.A. at 1-888-327-4236.
Let's pray for a recall!!!!
Aug 14, 2009 at 4:58 AM
MERLIN2021
  • 17,250 POSTS
Check the shaft in the throttle body for movement, should be none...open the trhottle part way, then push up and down on the plate, should not move (sideplay).
Aug 18, 2009 at 5:48 AM
CLEARANCEMAN
  • 14 POSTS
I hadn't checked this in awhile. My car now has 171,000 miles on it. It is pretty bad, I have to turn it on and off 6-7 times each day, I have tried every suggestion given to me and it hasn't helped at all. I think I will dump it on carmax when it needs its next timing belt at 195,000. Anyone ever find a solution?
Oct 16, 2009 at 12:20 PM
MERLIN2021
  • 17,250 POSTS
Right now only God seems to know!
Oct 16, 2009 at 12:27 PM
CLEARANCEMAN
  • 14 POSTS
I did call the NHTSA and I submitted my complaint. The biggest problem is the car is unsafe and cannot be made safe. It should be taken off the road.
Oct 29, 2009 at 12:25 AM
CLEARANCEMAN
  • 14 POSTS
I hope more people report their problem to the NHTSA because they won't open an investigation until they get enough complaints. Carmax offered me $500 for my car so I'm still driving it. It has 178000, I guess it's mine for now, I can't get anything for it and it works well in the snow when I'm not restarting it 5-6 times per day. I've gotten pretty good at restarting it. I drop it in neutral and restart wherever I am. Only place I can't do that is stop and go traffic up hill. Then I have to stop and restart.
Dec 22, 2009 at 11:51 PM
MERLIN2021
  • 17,250 POSTS
I wonder how many years this goes on for? A friend of mine bought a Subaru wagon, 2005 new, and before it got off the Dealer's lot, it needed a new TPS...
Dec 23, 2009 at 10:59 PM
GWLUND
I also have a 2000 Subaru Legacy with a TPS code and hesitating around 2000 RPM. It is intermittent and happens mostly when the engine is warm. My local shop has a Subaru knowledge base that says that the electrical wiring and/or connector is suspect. If you look at the 180 deg bend that the wire makes out of the TPS you can see why there might be an intermittent contact that causes the voltage reading to fluctuate.
Anyone tried to replace the wiring/connector? Looks like the dealer wants you to pay $300 to replace the entire wiring harness.
Feb 26, 2010 at 2:24 PM
GWLUND
Also, I've played with strain reliving the connector with zip ties and tape and can get the problem to go away for a few weeks but it ususally comes back. Might also be a bad wire that gets hot when you drive and causes the resistance to go up. Having an extra voltage drop in the wire can cause the ECM to see a low voltage. The best way to check is to wire in a shunt wire at the TPS and monitor the voltage in parallel to the ECM. If the ECM see a low voltage and the parallel meter does not then the problem is in the connector/wire.
Feb 26, 2010 at 2:28 PM
MERLIN2021
  • 17,250 POSTS
If there is a lot of tension at the plug, it could also be stressing the TPS itself? Test when hot!
Feb 27, 2010 at 12:44 AM
GWLUND
We found that the problem with our intermittent power loss was the TPS was installed incorrectly. The throttle lever was inserted on the wrong side of the TPS locator guides. Reinstalling the TPS solved the problem.
Nice to have a car that works again.
Mar 7, 2010 at 1:58 AM
MERLIN2021
  • 17,250 POSTS
Now that the TPS is installed correctly, is there any stress on the harness? Or did that resolve as well?
Mar 7, 2010 at 2:39 AM
CLEARANCEMAN
  • 14 POSTS
On mine, I replaced part of the harness to relieve tension and it did nothing at all to change the problem. I soldered all connections well.
However, someone at a local shop had the TPS wiring harness replaced when he did the timing belt and his problem went away. Might try the TPS positioning thing, but I think mine is correct.
I have found I get the flashing ATF triggered by the TPS most in low speed driving, when the car is cold, but there is some stumble even on the highway gliding down hills.
If you get a flashing ATF due to the TPS, the car is drivable in 2nd or 1st gear lately so if it happens at low speed, I drive it in 2nd until I can get to safe place to shift to neutral and restart.
Mar 9, 2010 at 1:46 PM
CLEARANCEMAN
  • 14 POSTS
[quote:a3fb7730c0="gwlund"]We found that the problem with our intermittent power loss was the TPS was installed incorrectly. The throttle lever was inserted on the wrong side of the TPS locator guides. Reinstalling the TPS solved the problem.
Nice to have a car that works again.[/quote:a3fb7730c0]
Can you describe in greater detail? I think mine is right but I want to be sure. Any pictures possible?
Mar 9, 2010 at 1:49 PM
CLEARANCEMAN
  • 14 POSTS
I think I finally fixed mine. Buddy squared the heads (shaved them), head gaskets, timing belt, drive belts, seals, etc. Anyway, he works for a Sube shop (not the dealer).
But he said he had a customer that replaced the whole main engine harness (goes to TPS, coil packs and about 10 other things) and that had fixed his random flashing ATF code.
I got one through his shop which can buy from the Subaru dealer at substantial discount. Anyway, I have driven it all week and can't get the TPS code or flashing ATF no matter what I do to it. The list on the harness is $179 for the 2000 legacy and it is some work to install. He had the engine out of the car and the engine down to the head gaskets, so it was no big deal to do it then.
Finally, there seems to be some tension where the TPS plug is on the harness, they just come that way. But on mine, that wasn't where the short was. I don't know where it was, but it wasn't right there because changing the plug and splicing the replacement plug in with extra wire to relieve the tension had not worked on the old harness.
Mar 19, 2010 at 11:39 AM
MERLIN2021
  • 17,250 POSTS
So it was most likely the harness all along, nice to have a friend that knows his S_ _t!
Mar 21, 2010 at 2:46 AM
CLEARANCEMAN
  • 14 POSTS
[quote:73cd37df28="merlin2021"]So it was most likely the harness all along, nice to have a friend that knows his S_ _t![/quote:73cd37df28]
Yes, and still the first time he had seen a solution for this problem was a couple months ago. Now they have fixed three of them including mine. The worst thing is if the intake isn't coming off anyway, he said it is about two hours labor to install so it isn't a happy fix if a lot of these are going out on people. Kind of ridiculous that a main wiring harness seems to be a maintenance item on a 2000-2004 legacy.
Mar 21, 2010 at 3:12 AM
MERLIN2021
  • 17,250 POSTS
I Agree! maybe in today's saftey recall environment, If enough people complain to NHTSA, ou can force a recall, this would entitle you to be compensated for the expense!
Complain here:
http://www-odi.nhtsa.dot.gov/ivoq/index.cfm
Mar 21, 2010 at 7:54 AM
GWLUND
[quote:f34a444e4b="clearanceman"][quote:f34a444e4b="gwlund"]We found that the problem with our intermittent power loss was the TPS was installed incorrectly. The throttle lever was inserted on the wrong side of the TPS locator guides. Reinstalling the TPS solved the problem.
Nice to have a car that works again.[/quote:f34a444e4b]
Can you describe in greater detail? I think mine is right but I want to be sure. Any pictures possible?[/quote:f34a444e4b]
It turns out that the TPS install was not my problem since the problem came back a few weeks later. I replaced the wiring harness with a used part and the problem has dissapeared. Looks like something in the the harness was impacting the signal from the TPS.
Apr 13, 2010 at 3:01 AM
MERLIN2021
  • 17,250 POSTS
It seems unanimous then, it's the harness...
Apr 13, 2010 at 5:14 AM
