1999 Subaru Legacy wont change gears properly after ignitio
116,000 MILES • 4 CYL • AWD • AUTOMATIC
HATCHETMOM
after the ignition has been off the car wont shift properly for a while then shift and runs fine after about a mile or so. awhile back the accelator cable was adjusted to up the idle a little. could this be related?
Mar 14, 2010 at 7:39 AM
KHLOW2008
  • 41,812 POSTS
Hi hatchetmom,
Thank you for the donation.
For idling speed adjustment, the throttle cable should not be adjusted to increase it. This would cause the TPS to indicate incorrectly and might cause erratic transmission shifting.
If the throttle body is dirty, it would cause the idling speed to drop. To restore the idling speed, cleaning the throttle body and Idle Air control valve is the proper way.
Mar 14, 2010 at 8:50 AM
