1999 Subaru Legacy trouble shooting a bad fix
15,000 MILES • 4 CYL • AWD • AUTOMATIC
OSCAR45
I recently changed the transmission filter and oil, and had problems when i was done.
the car only took about one to one and a half quarts of transmisson fliued so i tried to start the car put it in gear and got no movment. so thinking that it was because it was to full i went to drain some oil out and nothings comming out of the transmisson drain hole but yet the dipstick says that the fluid is over full. what did i do wrong?
Dec 12, 2008 at 11:02 AM
  • 31,937 POSTS
Hi there,
Remove the pan and check that the filter is installed correctly, and are you checking the transmission engine running and in neutral?
Mark (mhpautos)
Dec 12, 2008 at 5:21 PM
