1999 Subaru Legacy speedometer working intermittently
137,000 MILES • 4 CYL • AWD • MANUAL
DANGELOJ1
swaped guage cluster problem is still there, i want test vehicle speed sensor any info would be appreciated.
Oct 25, 2008 at 9:33 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect speed sensor
check for codes scan speed as you are driving does it show the same as the cluster ??
VEHICLE SPEED SENSOR
The vehicle speed sensor uses a Hall IC pick-up to generate speed signals. (MT models)
This sensor is installed on the transmission case and detects rotating speed of the transmission output gear.
The sensor generates 4 pulses per rotation of the speed sensor driven shaft and send them to the speedometer.
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 27, 2008 at 1:26 PM
