1999 Subaru Legacy Engine revs
1999 SUBARU LEGACY
DLCULBERTSON
Engine Performance problem
1999 Subaru Legacy All Wheel Drive Manual 223000 miles
My engine revs while accelerating and has no power. I do regular oil changes at 3000 miles and pamper my car. There are no odd sounds or other issues.
Feb 22, 2010 at 10:59 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 22, 2010 at 12:47 PM
