1999 Subaru Legacy Deafening Humming between 40 and 60 MPH
1999 SUBARU LEGACY
175,000 MILES • 4 CYL • AWD • AUTOMATIC
BLUEEXTC3221
I have a 1999 Subaru Legacy GT AWD with 175,000mi. I purchased it without a Freeway drive.
Going home, I noticed a slight humming at most speeds (barely audible).... figured it was the tires that were in need of changing.
Previous owner stated car was gone over with a fine tooth comb and replaced everything that was hinting of being bad.
Removed a wheel for closer inspection after arriving home because i suspected bad wheel bearings, and saw no problems. No looseness in the axle - lateral or vertical. Everything is tight. 1/2 shaft boots look new with no damage. Axle retention nuts look new... as if the axles have been recently replaced.
Fluids are correct, and at proper levels.
Took a vacation road trip to FL, and as soon as we passed 40MPH, it sounded like permanent rumble strips were under the car!! But it was only evident thru the construction zones - thats why im baffled. Between 40 and 60MPH we couldnt hold a conversation. After 60MPH its quiet as night!
This is an AWD vehicle - is there a torque converter or something else i can look into to resolve this?
The tires are brand new all season performance and balanced. We recently had snow, and the noise was still evident on ice/snow covered roads.
I did notice a slight lull when I went over railroad tracks @ 50 kind of BUMP JUMP. The noise lowered, but when the weight of the vehicle transferred back to the wheels, so did the sound.
The noise is constant during accelleration, coasting or braking - and stays constant even with the engine rpm fluctuation... (put it in N going 50, and revved engine. No change in sound.
Any insight?
Feb 3, 2009 at 6:48 AM
KHLOW2008
  • 41,814 POSTS
Hi blueextc3221,
Thank you for the donation.
From the description of the condition of the vehicle, seems the previous owner has tried rectification and done replacement and repairs on a lot of items and is now passing the lemon to you. Guess the tooth comb has some missing teeth somewhere, lol.
The symptoms suggest that the problem is drive train related and since drive axles have been repaired or replace, I would suggest checking the following:
1. Propeller shaft.
2. Propeller shaft centre support bearing, (highest possibility to be the cause).
3. Universal joints.
Feb 3, 2009 at 8:32 AM
