1999 Subaru Legacy cam & crank sensor
1999 SUBARU LEGACY
100,000 MILES • 4 CYL • AWD • AUTOMATIC
BUCKFEVER
how can i check the cam and crank sensor to see if they are working properly
thank you
Nov 1, 2010 at 1:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
CRANK SENSOR
Unplug sensor connector,using a digital volt ohm meter set on ac volts position.Connect the leads to the two pins in the connector of the crank sensor.Then have a helper crank engine over.You should see ac voltage,if not,then your crank sensor is bad.
CAM SENSOR
Pin 1 is +5V, pin 2 is Ground and pin 3 is the signal. Use analog voltimeter in pin 2 and 3. Crank the engine: the pointer of the voltimeter shoud oscilate in range 0V to 5V.
Nov 1, 2010 at 1:07 PM
