1998 Subaru Legacy Tail Light Assembly Removal
1998 SUBARU LEGACY
MIKE FREW
Electrical problem
1998 Subaru Legacy 4 cyl All Wheel Drive Manual
I am attempting to remove both tail light assemblies from my car without destroying them. I have removed the nuts from 4 studs on each assembly, can locate no more, however, the assembly still will not break loose.
Am I missing one or more studs/screws somewhere? What is the standard procedure for removing one of these assemblies?
Is there any "tricks" to employ? I am thinking that the rubber gasket may be "baked" on. I have tried tapping the studs lightly (did not want to break the plastic housing) but it did not come free.
May 2, 2010 at 7:09 AM
KHLOW2008
  • 41,814 POSTS
Hi Mike Frew,
Thank you for the donation.
There are 2 types of gaskets used.
One is the stick on type sealant which requires some force to slowly get the sealant to come off.
The other type is the sponge-like gasket type and it should be easy to come off.
Yours seems to be the sealant type and you would have to slowly force one side out and use a scraper to cut the sealant to remove.
May 3, 2010 at 3:54 AM
