HI, my car is overheating, I already change the thermostat and the radiator. My antifreeze is runing out to quickly every 2 days, the heater some time works and some not, I have a check engine light po325, I do no see water in the oil.
it' s overheating a 7 milles.
some pepple tell me that is the water pump
and others head gasket
hte car is working fine, no low power
thank you
SPONSORED LINKS
Wednesday, December 23rd, 2009 AT 2:09 PM
HILLDMI
MEMBER
I would replace the water pump that would be the problem if you have replaced that thermostat and such
