When the headlight goes out, does the whole unit need to be replaced or can you just replace a bulb?
Jan 7, 2009 at 6:12 AM
MIKE H R
MEMBER
you can just replace the bulb. You do have to take the lens housing out. there is a bolt on top under the hood that needs to be taken out and then the housing can be wiggled out. Once the bulb is replaced then install in reverse order.
Jan 27, 2009 at 1:25 AM
