engine light and code P0261?
134,000 MILES • 4 CYL • AWD • MANUAL
BRONCO410
Hi, my engine codes were P0261,P0264,P0267, P0270. I believe these are low circuit codes for all 4 cylinders. What should I try to fix this problem? At first it was the misfire codes, now the low circuit codes. I have replaced the spark plugs, wires, and coil already. I have also tried fuel injector cleaners.
thanks,
Bronco410
Jun 28, 2008 at 1:37 PM
Since you have multiple codes, I suspect you have a connector from the PCM to the injector harness that is not fully seated or it is a PCM issue.
Here is a guide that will help with the type of testing that we need to run through in order to figure this out:
I am attaching below the process from the manual on how to check one of these injectors. Please run through all this testing and let us know what you find.
Thanks
Jul 31, 2021 at 1:45 AM
