1998 Subaru Legacy 1998 Subaru Misses Going Uphill
1998 SUBARU LEGACY
158,000 MILES • 4 CYL • AWD • AUTOMATIC
KESCCO
My 1998 Subaru does fine until it goes up any type of hill. It then starts missing and almost feels like it is choking down.
Turning on the air conditioner makes it worse.
I have checked the air filter, fuel filter, and had new head gaskets put on it last year. It was leaking cooling fluid but I found the leaking hose and it has been replaced solving the problem. Also, it seems to be loosing a bit of oil.
What would be the first thing to do? Plugs and wires come to mind but I cannot figure out how to get the plugs out seeing they are so close to the frame.
Jun 12, 2010 at 3:04 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 12, 2010 at 8:05 AM
