1997 Subaru Legacy Water Pulling out of radiator into reser
19,700 MILES • 4 CYL • AWD • AUTOMATIC
MARCELLALEA
My husband changed the engine in my car because it overheated and we got a used engine. He also bought a new radiator and put in the car. The car still overheats.
What are we missing?
Thanks.
MarcellaLea
Apr 17, 2008 at 3:04 PM
  • 75,988 POSTS
Are the cooling fans coming on?
Apr 17, 2008 at 3:09 PM
MARCELLALEA
Yes the fans are running. The car is idling hard.
Apr 17, 2008 at 3:17 PM
MARCELLALEA
I gave $10 for an answer and only received a question back. I guess I didn't give you enough. How much is enough?
Marcellalea
Apr 19, 2008 at 2:50 AM
  • 75,988 POSTS
Your donation is very much appreciate was not listed as a donor. Myself I'll answer a question with or w/o money.
Okay -lets restart now its idling hard-I assumed all tune-up parts were done recently. Did you perform a compression check on the used engine if not do so.
You need to inspect and test the idle speed control solenoid/throttle position sensor/oxygen sensors/PCV and EGR valves. When you complete these tests and it checks out then comeback and I'll get into the more complicated areas to find this culprit-
Apr 19, 2008 at 9:13 AM
MARCELLALEA
Thanks. I'll pass this information on to my husband to check.
Marcellalea
Apr 20, 2008 at 4:43 AM
74XR7
  • 18 POSTS
See my reply to the question about the 95 that overheats. I found this out the hard way, myself.
May 22, 2008 at 7:41 AM
