1997 Subaru Legacy soft brakes---
1997 SUBARU LEGACY
190,000 MILES • 4 CYL • FWD • AUTOMATIC
208MLBOYER
I start from the begining-----change the front pads and rotors like i've done for years--but this time i did one thing different and colapsed the caliper without breaking the bleed screw and pushed the fluid back up in the reseivor---i don't usually do it this way but my friend told me that is the way he has always done it----not sure if any of this could be the root of my problem----------so the symptons are that i have good pedal without the car running but as soon as i start it the pedal goes to the floor-----I bleed the system 2 times because of possible air in the line. nothing helped--then i thought maybe it was the brske booster just from gathering info from around town----&300 later and another bleeding-Not the problem--i should probrably mention this is a right hand drive mail car--but not sure if that matters--any ideas would help---i have broke all lines loose around master cylinder and bleed system again but seem as if hard to get fluid to rear wheels
Nov 29, 2009 at 7:02 PM
  • 31,937 POSTS
Hi there,
normally there is no problem pushing the pistons back with out opening the bleeder, but i do feel that the problem is going to be your master cylinder, i would consider replacing this.
mark (mhpautos)
Nov 29, 2009 at 7:16 PM
